SCCA Autocross results thread
  1. CrookedRacer
    CrookedRacer Active Member
    I thought it might be a good idea to have a thread that helps track how we're doing.
    When you complete an autocross, submit a post here with the particulars so we can have it in a concise thread. Not to be confused with the SCCA Autocross setup discussion thread, which I have found quite valuable for the discussions regarding tires, pressures, etc.
    Include:
    1) a link to the results posted elsewhere on the inter webs
    2) your class and your setup (brief- we don't need to know your shift knob rocks)
    3) how you drove... Did you leave the a/c running? ( that's my personal go-to excuse )
    4) notes on your competition (nationals driver in a sorted celica, or a novice with three passengers)
    5) color of your Fiesta ST ( or whatever else you wish to add )
    If you think this is a silly idea, then don't. :poop:
    spangenb, k757 and Nik17 like this.
  3. AlanBDahl
    1) http://www.wwscc.org/event_results/2014/wwscc-02.html
    2) Pro (PAX) class running a GS index. Dunlop ZII’s 225/45-16
    3) Ran in the rain with Sport mode on, finished first by 0.003
    4) 12 drivers in class including 4 other Nationals-level drivers although two of those were in a Volt and one other in a borrowed but very fast STC Civic Si
    5) Performance Blue
  4. k757
    k757 Active Member
    I ran today at the Meadowlands, NJ (great surface)
    1) https://axwaresystems.com/axorm/files/MotorSportsNE/autox2014-03-30_fin.htm
    2) NASA auto-x group (E class), Dunlop Z2 (205/50-16), front pressure started at 38, rear was 37. Front tires need a lb or two more as the wear was about 1/3 down the wear indicator. Rear wear was not even touching the wear indicator.
    3) 45 degrees, mostly dry with patches of damp/puddles and high wind conditions. my first time with FWD, came in 3rd of 7
    4) not sure who my competition was, . my first time with this group.
    5) car rotated just fine with traction off. not as well in Sport mode (if at all). Was told that the car was tri-poding all over the place.
    CrookedRacer and Mightymango like this.
  5. limbo
    Here's my entry from the Dixie National Tour.
    1) http://www.scca.com/assets/results/Dixie Results4.pdf
    2) GS - 225/45/16 Dunlop Z2's. Stock otherwise.
    3) I drove well given my inexperience with nationals level courses. Was happy not to be DFL at 8/12
    4) Stacked with good drivers, it was a national tour after all. 2013's national champ in a Celica GT and Ian Stewart in a Volvo S60R took 1 and 2. I was hanging with the Focus ST's, didn't get a good idea of all of their mods but assuming they had more prep.
    5) Tuxedo Black
    spangenb, Smokin and CrookedRacer like this.
  6. eRic
    1) Class results[​IMG]
    it was Sunday, March 30 not Friday...
    2) G Street with OE wheels and tires set to 42 PSI front, 39 PSI rear. Green air filter. COBB shift knob. Perrin shorty antenna.
    3) Flat out. That's how I drive. Flat out.
    4) This was a Detroit Council of Sports Car Clubs [DCSCC] autocross not a SCCA SOLO event.
    5) Performance Blue
    Here is a link to the final results online.
    http://www.corvetteclubmi.com/images/Competition2014/033014_DCSCC.pdf
  7. Smokin
    eric, met a guy who knows you...Nate Sullivan. he's in KC helping fit Claycomo for the new transit van.. OUr first AX is Sunday...
  8. AlanBDahl
    1) http://scorekeeper.wwscc.org/results/nwr2014/1/post (Note: only the first three runs count)
    2) Open PAX class running a GS index. Dunlop ZII’s 225/45-16
    3) Mostly dry track with a few wet spots, finished 2nd
    4) 16 drivers in class including 6 other Nationals-level drivers
    5) Performance Blue
    First event in the dry, car worked pretty well but the wet weather pressures I started with were a little low. Raised everything 2 psi and it helped, would like to try another 2 psi the next time. I think the car could really use better shocks but the balance wasn’t as bad as I had feared. There was a Focus ST in the class too, he finished 11th about 1.6 seconds behind me.
    limbo likes this.
  9. eRic
    Nate? You mean Nick. good luck at your event
  10. CrookedRacer
    Wash DC Region practice event 4/6/2014 @ fedex field
    1) http://wdcr-scca.org/SoloAutocross/...4PracticeEventResults/tabid/1790/Default.aspx
    2) g-street, bone stock, tires ~38 front 36 rear ( I didn't have air handy so I ran it like I drive it)
    3) I over drove it. I got too aggressive in a few places and did a lot of push/scrub to get back to the course. On my last run I took some off, but maybe too much, since it wasn't any faster.
    4) nationals drivers in a sorted celica, several FoSTs with and without BFG rivals. I was actually pretty happy with 5th for my first time out there in 10 years.
    5) I was happy to see so many turn out for the class, including 2 other WHITE ST's ( even if they were the Focus kind )!
    I am really looking forward to the rest of the season!
  11. Travis T
    Travis T New Member
    What did you end up running as far as tire pressures? I haven't autocrossed in forever and am running the same tire setup.
    We've only had a test and tune so far, I tried a few different pressures. Started around 40 front and 35 rear. tried as low as 35 in the front, but that was a little too low based on feel and rollover. Think I'm going to try 38f/33r for event 1 in a couple of weeks.
  12. Smokin
    Kansas City Region
    Pax Time Results
    #1 - Event Number One - Sun 04-06-2014
    Timed Entries: 113
    Pax Pos. Pos. Class # Driver Car Model Total Factor Pax Time Diff. From 1st
    1 1 ds 99 Jeremy Salenius 2008 Mini Cooper 41.914 *0.815 34.159 0.000 0.000
    2 1 stx 39 Craig Wilcox 2012 Mini Cooper S 41.326 *0.827 34.176 0.017 0.017
    3 2 stx 9 Joe Silva 2008 Mini Cooper S 41.388 *0.827 34.227 0.051 0.068
    4 1 stu 45 Mark Hill 2006 Mitsubishi E-voh IX 41.192 *0.846 34.848 0.621 0.689
    5 1 gs 82 Jeff Bartz 2011 Hyundai Genesis Coupe 43.282 *0.806 34.885 0.037 0.726
    6 1 esp 96 Korry Berger 1996 Chevrolet Camaro Z28 41.107 *0.849 34.899 0.014 0.740
    7 1 stf 92 Nick Sullivan 2003 Ford Focus SVT 43.820 *0.801 35.099 0.200 0.940
    8 2 gs 28 Todd Hesskamp 2011 Hyundai Genesis 43.917 *0.806 35.397 0.298 1.238
    9 3 gs 23 K. Greg Cheney 2014 Ford Fiesta ST 44.088 *0.806 35.534 0.137 1.375
    10 1 bs 19 Nate Green 2003 Honda S2000 42.827 *0.831 35.589 0.055 1.430
    11 3 stx 165 Bob Buxbaum 1997 BMW 328 43.153 *0.827 35.687 0.098 1.528
    12 1 as 66 Rygh Galloway 2008 Porsche Cayman S 42.871 *0.833 35.711 0.024 1.552
    13 2 stf 42 J Douglas Patterson 2004 Ford Focus SVT 44.586 *0.801 35.713 0.002 1.554
    14 1 esr 9 Dan Wheeler 1991 Toyota MR2 43.153 *0.828 35.730 0.017 1.571
    15 4 stx 186 Michael Schulte 2013 Scion FR-S 43.227 *0.827 35.748 0.018 1.589
    16 5 stx 86 Pete Schulte 2013 Scion FR-S 43.272 *0.827 35.785 0.037 1.626
    17 3 stf 4 Paul Moylan 2003 Mini Cooper 45.098 *0.801 36.123 0.338 1.964
    18 1 csr 55 Steven D Roberts 2007 Mazda MX 5 MS-R 43.357 *0.834 36.159 0.036 2.000
    19 6 stx 65 Kent Edmondson 1997 BMW 328is 43.796 *0.827 36.219 0.060 2.060
    20 7 stx 191 Douglas Hitchcock 1998 BMW 328is 43.889 *0.827 36.296 0.077 2.137
  13. Smokin
    Sorry, trying to post a little bit of the results. Finished 9th out of 109 cars. Paxed 1.375 secs out of first. The GS Genesis is dialed in and has the advantageous eccentric camber bolts running I think -2.5 degrees. He was one of my prodigies. it will be a competitive season...
    BTW, I settled on 42# front, 32# rear during the T&T Saturday. The car rotates beautifully. Easy to get the tail out with just a slight turn-in and lift. Peeps said it three-legged beautifully.....
    spangenb likes this.
  14. Smokin
    Maybe this will be better....
  15. Cligedy
    Central Carolina region Event #2, 4/5/14, 201 drivers put in times. Only mods are tires & cg lock. 1st in GS out of 7, 30th pax. Overdrove the car every run, course was hella hard; over a 75 second course, car was only settled for ~4 seconds.
    http://ccrscca.proboards.com/thread/6327/2014-solo-results
    Mightymango and spangenb like this.
  16. Mightymango
    Holy crap long course Cligedy!!
  17. Cligedy
    We probably have one of the best lots in the Southeast, at Zmax dragway. I hope to have a decent camera setup before the next event, but there are plenty of zmax autocross vids on YouTube. [​IMG]
  18. k757
    k757 Active Member
    1) http://fcscc.com/joomla/results/140413_event_pax.htm
    2) local SCCA club (GS class), Dunlop Z2 (205/50-16)
    3) 1st of 3 in GS, finished 7th of 110 overall. I'm still learning to drive FWD (came from an AWD)
    4) competition included multiple national champions in this club
    5) Sport mode, tire pressures were 40 around
  19. Couldahadav8
    Couldahadav8 Active Member
    http://www.sccaforums.com/forums/aft/445563
    Placed 3rd of about 40 in PAX. 2nd (by a mile) to Trevor Jones in GS. Conditions were abominable. 45 degrees and moderate consistent rain. By the end of the day, the finish was done by rudder. Ran 215/45/17 rivals. Switched out the oz's for stock wheels in front after issues with clearance in the front last week. Ran ghetto with stock wheels in front and OZ's in back. By the way, the OZ's are very light compared to those stock wheels. Fastest times were in sport mode. Jones was 2nd at nats in RTR last year. He was driving a Focus ST, which is new to him this year.
  20. Mightymango
    I didn't know Trevor switched to the Focus, he was pretty damn good in the BR-Z last year.
  21. Couldahadav8
    I think he's been in a genesis coupe, brz, and now the focus st in the past few years. Fast in every one.
