SCCA Autocross setup thread
  1. Nik17
    Nik17 Member
    Ah. Well I'm definitely interested, and I'm sure lots of other folks are too as there isn't too much info out there about what fits and doesn't right now. Keep us posted!
  3. limbo
    I ordered the Eibach rear bar from TireRack. Hoping it'll get here in time for our test and tune day 3/3 so I can test it out before Dixie.
  4. Des
    Des Active Member
    215/45/17s mounted. No issues in street driving, no rub at full lock (shiny spots are tire dressing the installer put on). I'll chalk the edges at the next event to see if it's contacting those weird burlap fender liners.
    Cligedy likes this.
  5. RavynX
    RavynX Member
    That Z2 size looks perfectly fitting for the wheel & fender, nice.
  6. RodMoe
    Nice looking tire
  7. k757
    k757 Active Member
    picked up today: 16" Sparco with Dunlop Z2
  8. Slowclimb
    Really interested to see how the 205 50s perform...still not convinced putting a wider tire than that on a 7 inch rim will give you anything.
  9. k757
    k757 Active Member
    It'll be a while to know how they do. I had the Z2 on my WRX and they were a bit greasy until about run 30. It all depends on how quickly I can get these heated up.
    I suspect it will be the same as the vast majority are amateurs. There might be a difference when professionals are going head to head
  10. Des
    Des Active Member
    I've run 215s, 225s and 235s on my FR-S' 7-inch rims. Most folks running the car on ZIIs choose a 235; the stiff sidewall helps.
    Slowclimb likes this.
  11. Slowclimb
    Thanks. That is good to know.
  12. limbo
    Agree with Des, Z2 sidewall is very strong. More surface area is always going to be a good thing until the tire gets too pinched.
  13. RodMoe
    Loved my DZll on my FRS too . You talk to anyone that ran BFG Rivals ?? tring to get a feel for tham as Dunlop is not making my size i want in a 15..
  14. Des
    Des Active Member
    Very grippy but you do miss the crispness of the ZIIs.
  15. Des
    Des Active Member
    215/45/17 update:
    No rubbing anywhere. I chalked the strut and the fender lip. Not as much rotation as I had hoped, with front pressures at 42 and the rears anywhere from 28 to 48.
    Looking forward to the rear bar.
    Gearing was fine (second now goes to ~61); launch didn't seem affected -- plus the super short first is a bit longer, which helps with kinked starts.
    This was BMW club so difficult to gauge relative performance. Overall time was third fastest of 110, about 1.4 seconds behind an STU-prepped M3 driven by a (good) driver I know. Pretty sure that a bit more rotation would have cut the .4 off, maybe more.
    Nik17, k757 and Cligedy like this.
  16. Slowclimb
    What are your alignment settings...would toe out in the rear help
  17. RodMoe
    Thanks looking forward to more info on the rear bar..
  18. Des
    Des Active Member
    No alignment changes yet -- I'll wait to see what the rear bar does and adjust toe if I still can't get the car to spin.
  19. Nik17
    Nik17 Member
    Some good info Des. I have to ask though, what made you pick the 215/45 over the 215/40? I would think the 215/40 would have a stiffer sidewall
  20. RodMoe
    interesting to hear also ..
  21. Des
    Des Active Member
    A little more sidewall helped the ride quite a bit! But actually chose it for the gearing, now ~61 in second. The 215/40 was only a tiny bit taller than the 205.
    As much as I would prefer a 40-series, no one makes a 225, and no one's tested a 235/40 yet. I intend to.
    Cligedy likes this.
