spark plugs for stage 3?
Discussion in 'Fiesta ST EcoBoost™ Tuning' started by 14st, Nov 23, 2014.
  1. 14st
    14st Member
    Any recommendation s on spark plugs for cobb stage 3? Or are factory plugs fine?
  3. Dyn085
    Dyn085 Active Member
    Factory plugs are fine.
    timboslice likes this.
  4. aar0n
    aar0n Member
    Stage 3 is kind of a joke imho. I feel stage 3 should be stage 1.5. It is not the same as different stages on other cars. The last car I was working on, the stage 3 was a complete upgrade with exhaust manifold, turbo, wastegate, steel braided lines, etc.
    Fixing imperfections in the manufacturers design shouldnt be considered stages but maybe one or 1.5 stages. (FMIC, intake, exhaust, etc)
  5. 14st
    14st Member
    This isn't a thread about your opinions on the stages.
  6. RDgolfer
    RDgolfer Active Member
    NGK LTR71X-11 Iridium...ordered 8 to index...hopefully that is enough...and be nice...ha ha
  7. RDgolfer
    Are you a FiST owner? If so, start buyin' or continue cryin'...you don't think Ford was gonna build you a razecar, did you? The last time that happened, Ford built 200 road legal versions of a Group B rally car to comply with FIA homologation regulations...now give me RS200 plz!
  8. 14st
    14st Member
    Can you post a link? Not finding these
  9. aar0n
    aar0n Member
    You're right. I was indicating that the logic behind changing plugs for the small increase in power you are getting with a marginal(none?) increase in boost is quite hilarious. Why in gods name would you need to change plugs for the most basic of upgrades? If you used the search button you would see the only people talking about changing plugs were the ones going to a "colder" plug which in itself is comical but I guess personal preference.
    I assumed you meant stage 3 "tune" which is literally a tune of stock parts with other parts that their only function is increasing airflow into and out of the motor. More air means different plugs? Maybe if it was more boost....
    Besides increasing flow into and out of the motor with a tune that utilizes the stock parts I dont see any mods out that would require different plugs except for the upgraded turbo.
    I guess my assumption is that smart people learn what the function of parts are before giving away their money to waste on new ones and that some people would actually research things before posting questions that the answer is easily found for.
    Qlean_Kutt likes this.
  10. RDgolfer
    Pelotonracer2 posted a long time ago about modifying and indexing spark plugs...on another forum...I should get residuals...google it
  11. 14st
    14st Member
    I WAS asking for a colder plug. And if its fo the most basic upgrades, then how do you explain the ford racing kit for the focus st? Just a tuner and colder plugs. Instant +90 torque. They wouldn't add the colder plugs for fun
  12. RDgolfer
    Check Amazon
  13. aar0n
    aar0n Member
    My mistake, I thought you were inquiring about a fiesta. Carry on.
    But, a quick search on google you would find a thread on a different forum that shows viable options for a colder plug. Just saying. I guess I just am used to people doing research before posting questions. Residual left over from another forum.
  14. RDgolfer
    NGK LTR71X-11....sorry, left out the 7
  15. Dyn085
    Different engine, different requirements.
    Those have been proven to not fit and are causing issues. There is no colder plug available for the FiST.
  16. RDgolfer
    Elaborate please...I wasn't aware the NGK spark plugs I bought, as a direct replacement for the oem plugs, don't fit and cause problems...that's weird
  17. Dyn085
    Definitely not a direct replacement as stated by NGK-
    And a picture-
  18. RDgolfer
    Well, I wonder why Amazon sells these as direct replacements...looks like I'll be returning these plugs
  19. 14st
    14st Member
    Well there goes that idea. Never mind then
  20. Dyn085
    Fwiw, Amazon is not an auto parts store.
    iLiptiKal likes this.
  21. RDgolfer
    Yeah, just talked to technical support at NGK, "currently we have no products for the 2014 Fiesta ST"...Ok...back to square one...now buying oem spark plugs to index and modify
