stage 3?
Discussion in 'COBB Tuning' started by 14st, Nov 15, 2014.
  1. 14st
    14st Member
    So do I absolutely NEED the high-flo cat that comes with the stage 3 kit? Already have a 3" cat-back
  3. ghostwhite
    ghostwhite Active Member
  4. 14st
    14st Member
    So I can't run a stage 3 tune?
  5. FORZDA 2
    FORZDA 2 Member
    So you're saying you want to run stage 3 but still have the stock DP/cat?
  6. 14st
    14st Member
  7. 14st
    14st Member
    I mean high flow cats generally aren't worth it
  8. Eric Hamann
    Eric Hamann Member
    You'd be surprised how much they matter on turbo cars
  9. 14st
    14st Member
    Because I just shelled out $1700+ on the fmic,hard pipe kit, intake and ap v3
  10. 14st
    14st Member
    It would only be stage 3 91 octane
  11. FORZDA 2
    FORZDA 2 Member
    You can run the stage 3, but you won't get the performance intended without the high flow DP, regardless of whether it has a cat or no cat. The oem DP is terrible for good exhaust flow. The oem cat itself isn't the problem...
    This is turbocharger 101 information. Just search for the actual data and don't bother with opinions...
  12. aar0n
    aar0n Member
    Any high flow DP will do, ATP makes one for $250 and so does 2JR for $250 as well. (these are both without a cat but the ones with a cat are way more competitively priced compared to others)
  13. EvilFist
    EvilFist New Member
    Just be careful about the catless DP. You will get a tad bit of over boost.
  14. Dylanc
    Dylanc New Member
    Check out depo racing also. I just got their catless one for 179.99 no issues at all and good quality. Only 279.99 for a high flow catted version
  15. Izzy
    Izzy Member
    I've seen .5 to .9 PSI of overboost with my 2J-R catted it can happen with a well designed catted version as well. I don't mind it cause it's not extreme and the AFR stay well within reason.
