SYNC: astounding stupidity! Caution, rant ahead...
Discussion in 'Fiesta ST Chat and Discussion' started by reddog99, Oct 4, 2013.
  1. FordIVTteam
    Hi Firesail,
    You may be correct; I wasn't sure. :)
    Currently, most iPhones do allow text messages to come in. Unfortunately, text messages can't be sent out (according to feedback from other owners). iOS 7 hasn't been added to our compatibility chart yet, so I am unable to verify.
    Hello ohskigod,
    If you're interested in learning more about it, check page 310 of your owner's manual (printing 3):'s-Manual-Third-Print_om_en-us_10_2013.pdf
  3. LuvfiestaST
    LuvfiestaST Active Member
    Tried it again no luck..;((
  4. LuvfiestaST
    Hence why ford should have went with Apple
  5. Sil3nt611
    Not even... If that was the case, Apple is so proprietary that the only things that would connect to it are Apple devices.
  6. LuvfiestaST
    That works for me
  7. FordIVTteam
    Are you running V3.6.2 on your MyFord Touch system?
  8. Mayhem
    Mayhem Active Member
    I have found the problems to be really dependant on the device in use.
    Certain devices work really well, and others cause constant problems.
    I don't ever experience the same problems, with the devices that work well as I do with the others.
  9. Cligedy
    Device independent problems are what frustrate me. I asked sync to call my wife on her cell, and it tuned the satellite radio to a jazz station. Switching to bluetooth audio always requires a tap on the display. The voice command trees are rigid and not always intuitive.
    I get the impression that the system works great if you have a deep understanding of how it works, but short of that, I find myself screaming at the system to get its shit together.
  10. FordIVTteam
    Hi Cligedy,
    Which type of phone are you connecting? When you say it requires a tap on the display, do you mean the MyFord Touch display or the phone?
  11. Cligedy
    Sync says that the bluetooth device isn't connected and that the system will try to connect to the previous device, even though the phone is connected. Before sync even finishes what it is saying, a "successful" shows up on the entertainment corner. If you tap the successful message, then the audio starts right up.
  12. FordIVTteam
    One thing you can do to improve the connection for Bluetooth audio streaming is a soft reset. If your phone allows you to remove the battery, take it out and replace it. Start up the car and see if you notice an improvement. If you have an iPhone, the soft reset is done by pressing HOME and POWER until the Apple logo appears.
  13. Removed
    So I guess random complaining, but...
    MyFordTouch does this annoying thing where you can say "Call John Doe" and then it will prompt me, "please choose" with a list:
    1. John
    2. John Doe
    Even though John Doe is the only John in the address book... it's things like this that make me wonder if the designers were on meth.
  14. __V__
    __V__ Member
    Let's see if anyone else has this problem with temp control.
    With all temp control off, tell sync set car temp to a temp different than it was before you turned it off. So set temp manually to 65 then turn it off.
    Now tell sync set temp 67
    Every time I do it it will turn on the blower but the temp always will be 65 not 67.
    Once it is on it will set the temp correctly but not from an off setting.
    Minor thing but it's repeatable.
