Sync constantly Indexing device....
Discussion in 'Fiesta ST Chat and Discussion' started by LotusZX3, Oct 28, 2013.
  1. LotusZX3
    LotusZX3 Member
    I have a Zune HD going through the USB port and I thought it would be the perfect match. However, every time i would start the car SYNC would have to Index the Zune and I would usually be at work by the time it would finish. Finally took the time to try to fix it and now everything works flawlessly and the voice commands are great. I pulled the #10 Fuse (SYNC fuse) from the passenger fuse compartment to reset it and at the first startup it indexed and built commands in just a few seconds.
  3. kvetcha
    kvetcha Active Member
    The old iPhone I leave plugged in for music takes a few minutes to index every time I start the car. Maybe five minutes?
    You'd think it could store the index locally.
  4. mcummings182
    mcummings182 Member
    Sometimes my ipod takes a few minutes to index, but that's because its 160 gb and I have over 17,000 songs lol
  5. FordIVTteam
    Hi kvetcha,
    I recommend performing a soft reset to your iPhone. Unplug it and hold the POWER and HOME keys until the Apple logo appears. Check the compatibility of your phone here: http://support.ford.com/sync-technology/device-compatibility-sync If it's listed as a device that can connect via USB, it should only index one time unless new music has been added.
    Kim
  6. kvetcha
    I'll give it a shot. Thanks, Kim.
  7. FordIVTteam
    You're welcome. Let me know how it goes.
    Kim
  8. mcummings182
    mcummings182 Member
    Something weird happened with mine. I have all album artwork for all of my music on my ipod and they were all showing up until today. It stopped showing most of the album art. Why did this happen and how do I fix it?
  9. FordIVTteam
  10. LotusZX3
    LotusZX3 Member
    Greaaaatttt :/ Back to listening to the Radio instead of my music because SYNC wants to index the device constantly. I hope that pulling the fuse isn't going to have to be a recurring thing....
  11. FordIVTteam
    Hi LotusZX3,
    Powering down your device and turning it back on may help resolve this indexing concern. Give it a try, then reconnect the USB cable.
    Although your device can play music via USB, it may not be fully compatible since it's constantly indexing. The device should only index the first time you connect it after adding new music. To see which devices work well with a USB connection, check the box that says CONNECTS VIA USB on this page: http://support.ford.com/sync-technology/device-compatibility-sync-myford-touch
    Kim
  12. Bluto
    Bluto Member
    FWIW I'm using a 32GB Sandisk Cruzer Fit (storing CD's ripped to 256K MP3's)
    and long index time has not been a problem so far though it is not full yet....the tiny size works well as it much less likely to get damaged in the console....if I was listening to music on it the last time I drove it starts up immediately when the car does. They are available up to 64GB and since we have two USB ports you could store a LOT of music.
  13. LotusZX3
    LotusZX3 Member
    After shutting it down and restarting it there is less load time. I actually got to hear some music on the way to work this morning. Thanks.
    I don't see how a Zune HD wouldn't be compatible being the top Microsoft music device.
  14. FordIVTteam
    If the Zune seems to be working correctly now, there's a chance it just hasn't been tested and added to that compatibility chart yet. The list just shows devices that have been verified as being compatible.
    I recommend restarting your Zune once a month to make sure constant indexing doesn't become an issue again.
    Kim
  15. LotusZX3
    LotusZX3 Member
    Thanks for the advice Kim. It's nice to see the effort being put in to help the end users. I really appreciate it.
  16. FordIVTteam
    You're welcome; I'm happy to help out where I can. Thanks for the kind words. :)
    Kim
  17. Davin Dameron
    Davin Dameron New Member
    I'm having the same issue with my Zune. Every time I start my car it takes at least 5 minutes to index. Sometimes it takes 30 minutes or more. Powering off the device does not help and resetting the fuse does not help. The device is on the exact version listed in your compatibility guide.
    LotusZX3 likes this.
  18. silvertoy
    silvertoy Member
    I'm using the 64gb version of that same sandisk drive, only $25 at best buy. I've got about 50gb on it, I've never seen it index yet.
  19. Davin Dameron
    When that $25 device is capable of playing the Xbox Music DRM protected content I will then consider it a viable alternative.
  20. LotusZX3
    LotusZX3 Member
    I still have issues on occasion and its annoying. For me the car outweighs the crappiness of the SYNC system though. I doubt they will do anything to remedy it since the zune product line is now extinct.
  21. silvertoy
    silvertoy Member
    Ahhh, bummer, (yeah, i never jumped on the DRM bandwagon, always wanted to actually own my music, Amazon, Google play, etc) Be a trailblazer - Put your Xbox in your fiesta and use the line input ;)
