Synch works great!
Discussion in 'Fiesta ST Chat and Discussion' started by Gpfarrell, Feb 11, 2014.
  1. Gpfarrell
    Gpfarrell Member
    Seriously, it's not perfect but I feel it works great. It ties into my faithful i-phone 4 and functions fine. The NAV seems fine, the weather and other Sirius stuff works great too. The little compass is cool.
    I just posted this so anyone reading here could see some of us think it's all it should be.
    Slowclimb, F1ST and LuvfiestaST like this.
  3. WScottCross
    I agree. It's not perfect, but there's more that I like than what I dont.
  4. F1ST
    F1ST Member
    I feel the same. This is my 3rd car with Sync and it works great with my iPhone(s).
    The version in the ST is the best yet.
  5. FordIVTteam
    Awesome to hear it, folks! I've already spoken to most of you, but I'll be here if you have questions about your system. :)
  6. F1ST
    F1ST Member
    Since you mention it....
    I would really like the steering wheel << and >> buttons to mimic what they do on the radio panel (during FM function at least). Currently they only go between presets when pressed short or do some sort of seek that doesn't work right if I hold them down. Is there any way this could be set in a menu option setting?
    What is it actually supposed to do when held? If I let go sometime it goes back to the station I was on.
  7. FordIVTteam
    Hi F1ST,
    When the SEEK button on the steering wheel is pressed, the radio will tune to the next saved preset for that category (AM, FM, SiriusXM). If you hold down that same button, it will go through all of the channels until the button is released. There is also an option to SCAN through the stations if you'd like to hear a preview of each one. This is in the ENTERTAINMENT section of your MyFord Touch system. Press this button and it will stay illuminated while the SCAN feature is activated. When you hear a song you like, press the button again to stay on that channel.
    You'll find more information on page 64 and 316 of your owner's manual (3rd printing):'s-Manual-Third-Print_om_en-us_10_2013.pdf
  8. dmondi12
    dmondi12 Active Member
    I agree, after reading reviews i wasn't expecting much but now that i have had the car for a couple months i'm surprised at how many people rip on the MFT system in the FiST. Its small but i've never found it too small and its connected to my HTC One before the rpms even come back down after ignition. I also like how minimal it allows the rest of the center console to be.
  9. Mayhem
    Mayhem Active Member
    I was pleasantly surprised at how well it worked when all I used with it was my iPhone. The good ol days .
    Sent from my SGH-I337M using Tapatalk
  10. Mayhem
    It seems much improved over previous versions I've used. But obviously not equally compatible with all devices. Great to hear some positive stories though for a change. Forums tend to dwell more on issues than what's working well.
  11. Ronbo
    Ronbo Member
    I have a question I can't find an answer to in the manual:
    If I leave an iPod plugged in to the USB port, will it cause a parasitic drain to the car's battery when the car is shut off?
  12. Firesail
    I can tell you from my personal experience that the USB charging power shuts off when the ignition is off. I had hoped to use the usb to charge my phone while the car is parked, but alas, no power when switch is off.:(
  13. onederer
    onederer Member
    it took a while but, I've gotten used to Synch. While not as smooth and easy a time as I have had with Googles Seach (voice) it works well enough.
  14. dmondi12
    I can tell you that if you have a USB charger to plug into the cigarette lighter, that WILL charge your phone while the car is off.
  15. Firesail
    That is true, but I wanted to hide the cord and not use the 12v outlet.
  16. Ronbo
    Ronbo Member
    Thank you!
  17. FordIVTteam
    Hey Ronbo,
    Looks like Firesail beat me to it! You can leave the iPod plugged in while the vehicle is turned off. It will not drain the battery.
