The COBB Fiesta ST R&D Master Thread
Discussion in 'COBB Tuning' started by COBB, Aug 22, 2013.
  1. timboslice
    timboslice Active Member
    I've had it in for a few weeks... It is kinda noticeable but definitely not harsh or uncomfortable. I notice a little extra vibration, on cold starts, when I turn the car on the morning and when the AC compressor comes on. Even then, its nothing you would notice if you didn't know about the new RMM and were looking for extra NVH.
  3. bobjob
    bobjob Active Member
    Looks like there is a v103, its not posted on their website but you can figure out how to change the url for the old file and get it.
    hxxps://static.cobbtuning.com/cobbtuningweb/site/maps/Ford/All%20Maps/Fiesta%20ST/FORD_US_FIESTA_ST_14/Stage1/v103/Stage1%2091%20v103.ptm
    Dunno if its a beta or will be official later today.
    iLiptiKal and BlackBird like this.
  4. BlackBird
    Looks like v103 is up. I'll have to load up APManager and transfer the files to my device and try it out tonight.
    iLiptiKal likes this.
  5. COBB
    COBB Active Member
    Yes, they have been upreved.
    Cheers,
    Braden @ COBB
    BlackBird likes this.
  6. BlackBird
    Any map notes/ change logs? Thanks for your hard work!
    Sent by my GS4 via Tapatalk.
  7. bobjob
  8. BlackBird
  9. bobjob
    Adjusting the rpms is software tuner only, but the OTS map has those features enabled as stated, at 5krpm for ffs.
  10. BlackBird
    Not sure I completely follow. I may have misread.
    Does v103 have LC and FFS enabled by default? If that's the case, I probably won't flash it because I don't want FFS, at least not on my daily map, unless I can switch it on or off with the device. Not that I wouldn't mind trying it out. I hope COBB updates their map notes PDF to make it a bit more clear what changes are being made for this revision.
  11. COBB
    COBB Active Member
    Yes it is enabled, however the way you shift is still up to you. If you accidentally forget to lift the throttle above a 5000rpm shift, we will be there for you and prevent an over rev!
    Cheers,
    Braden @ COBB
  12. BlackBird
    Brilliant. :D I'll have to try it out then. Oh, by the way, not sure if anyone's spotted this typo, but under the Stage 3 map table on the site, the two maps are labelled Stage2.
  13. mrtn
    So is the new map the release for this month?
  14. bobjob
    parts thurs
  15. mrtn
    Ohh ok thanks.
  16. Ronbo
    Ronbo Member
    Are LC and FFS the only changes to the v103 maps compared to v102?
  17. BlackBird
    Unless I'm blind I don't see any options for LC in the AP menus, so I'm guessing it's still only through ATR?
  18. Firesail
  19. BlackBird
    I'd read that. The map notes aren't updated to reflect revision 103. But I figured it out anyhow a few moments ago. You basically hold Cruise Set with the throttle pegged to get a throttle-cut limiter at 4k.
    Braden or Ian: What's the limiter set to if you don't have Cruise ON held?
  20. BlackBird
    I should add, keeping my eyes posted for any updates on new parts so I can provide links on the ST aftermarket master thread. :O Looking forward to what's new.
  21. timboslice
    Firesail and BlackBird like this.
