Tow Hook/Loop
Discussion in 'Fiesta ST Road Racing' started by MLKN, Jun 25, 2014.
  1. MLKN
    MLKN Active Member
    I know this has been brought up before but I still have not seen a good solution. Has anyone found a bolt on solution?
    Before I dump my car into the sand at Laguna Seca I want to know that they don't have to pull me out by my A pillars.
  3. Mr UFO
    Mr UFO Active Member
    When are you going to Laguna?
    I'll be there on Labor Day w/ NCRC.
  4. MLKN
    MLKN Active Member
    I was considering with NASA late in July. Every track in NorCal has a great Labor Day event but I'll be at a family function. :(
  5. was-an-M
    was-an-M Member
    Still no solution that I know of.
  6. raamaudio
    I am going to address that soon but whatever I do may be custom to my fairly modded car and not work for others but I will see if I can make it so it can be used by those needing them.
  7. iLiptiKal
    iLiptiKal Active Member
    Are you thinking of a hook or a loop for this? I'm not a fan of the JDM style red tow hook on a daily, but a nylon loop that you can tuck away could prove useful considering we don't have a stock option.
  8. raamaudio
    I have done both and prefer a nylon hoop I can tuck in and hide decently so that is what I will be working on:)
    Looked at it today but did not work out any plans yet.
    Firesail, jimclark and iLiptiKal like this.
  9. MLKN
    MLKN Active Member
    Just following up on this. Anyone found even a factory tow point under the car? I am tired of being asked "Where's your tow hook?" by the marshals on the grid lining up for the track.
  10. CrookedRacer
    CrookedRacer Active Member
    Anyone have a solution for this?
    I'm on the track enough these days that it might be something worth having, just so I'm guaranteed that I'll never need it.
  11. CrookedRacer
  12. haste
    haste Member
  13. CrookedRacer
    Well, I just may be welding up one of those for myself. Sounds like it is one of the few options we have. I wonder if they ever tested it under tow?
  14. meFiSTo
    meFiSTo Active Member
    Ordered one yesterday. Looks perfect and the attachment looks plenty stout. I reckon you could weld it on there for added securement, but I think the crashbeam itself maybe is going to be the "weak point" (which is to say I think it would take a lot -- think car fully stuck in quick sand with just the bumper showing -- to defeat this approach). No matter what, most any front tow hook solution is probably going to attach to the crashbeam in some way. Maybe a welded-in tow hook (no screw-on element) with a strap would be more secure.
  15. raamaudio
    I drilled a hole through the bumper beam and bolted a tow strap to the back side of the beam, long enough to go over the top and then just opened up a bit of the grill to tuck it through. Drilling the beam was interesting as pretty hard steel but other than that a pretty simple, effective, low cost mod:)
    I am going to do the rear next.
    Sorry no pics, if I come across some I will post them, I sold the beam, etc so no longer here to take any of it.
  16. McRib 1s Back
    I just posted a couple shots of the FRPP hooks in my "race car prep" thread. It looks pretty good, but requires welding and bumper modifications.
  17. Turboduck01
    Turboduck01 Member
    Eureka! haha. I never even thought about using the hitch as a tow point in the rear! My only concern would be using hollow vs solid bar stock... in my brief search I haven't seen anything for solid bar stock and the hollow recievers are rated for a 4000 lb ATV winch... whatever that means.
