tpms question
Discussion in 'Fiesta ST Wheel and Tire Upgrades' started by doudou, Nov 10, 2013.
  1. doudou
    doudou Member
  3. BRGT350
    So far, I have had luck installing TPMS sensors on any wheel. I am sure there are plenty it won't fit, but I have not run into that yet.
  4. WScottCross
    I think it just needs the threaded hole to screw the sensor into. I guess you could drill and tap a hole, but I don't think I'd take that chance myself.
  5. BRGT350
    The sensor is either attached via a band (big ass hose clamp) or is part of the valve stem. The Fiesta uses the sensor/valve stem combo. The only clearence issues would be if the wheel geometry won't allow enough room for the sensor to fit around the valve stem hole. If that is the case, a band style would need to be used.
  6. doudou
    doudou Member
    i come back to the dealer and he say , the car has no ring just the light at the Dashboard ,can i have the real thing , because i no need tpms just for the light but the ring is another story .
    thank s all for your help ;)
  7. doudou
    doudou Member
    hi all
    have you a sound tone , when tpms is not on the car or just the light
    thank s
  8. RodMoe
    I get just the Light and a warning on the MFT display the warning only lasts like 5 seconds and the light on the dash blinks for a bit then stays on solid. No dings at start or during .. (as I park my car near my summer tires so tpms resets itself in my garage) So I have to drive more than 15 minutes or so before it comes back...
  9. doudou
    doudou Member
    :thumbsup: thank s rodmoe
