What is this thing I found in the glovebox?
Discussion in 'Fiesta ST Chat and Discussion' started by maelkoth, Feb 12, 2014.
  1. maelkoth
    maelkoth New Member
    have a looksee…
    I did not have one of them .. hmmm when are you at ??
    ronnie karlen likes this.
  4. maelkoth
    maelkoth New Member
    i'm in los angeles…I flipped through the owner's manual…which revealed exactly nothing….probably a random tool a mechanic forgot after the dealer prep…initially the white key thingy was discovered loose in the glovebox…that black plastic c clip on the left side of the glovebox just happened to make a nifty holder…i also have no idea what function that black plastic c clip is supposed to perform...
  5. Flaco1
    Flaco1 Member
    That black plastic clip would be for a tire gauge or perhaps a pen !
  6. RodMoe
    But what is the curious white thingy ??
  7. captainmorbid
    captainmorbid Active Member
    So that's where I left that...
    CarefreeAZ likes this.
  8. Mayhem
    Mayhem Active Member
    Mine activates the undesirable passenger ejector. Used to have it hooked up to the trunk monkey. Not as cool as the glow in the dark rape escape button in the trunk of the camaro's.
    Sent from my SGH-I337M using Tapatalk
    reddog99 likes this.
  9. MLKN
    MLKN Active Member
    I was told it was a fuse puller by the dealer
  10. Cligedy
    I noticed that clip in my glovebox, but mine's empty
  11. Firesail
    Same here.
  12. BRGT350
    Out of all the Fiesta's I have been in, none have that thing present. The fuse puller is typically in one of the fuse boxes, stuck to the lid from what I remember. I have only looked at the fuse box once, so I don't totally remember.
  13. LotusZX3
    LotusZX3 Member
    I looked for a fuse puller when i first reset SYNC and never found one. Maybe you got lucky and got one or maybe i dooooo have one and i'm blind.
  14. maelkoth
    maelkoth New Member
    nah…not a fuse puller since it doesn't have a chomping bit at the top….i took a pic of what looks like a clock imprinted on the tip of the head…worst comes to worst i'll post to reddit.com/r/whatisthisthing…thought it would be a fiesta thing but it appears not to be since nobody else has one…thanks for the help
  15. mamiata1
    mamiata1 Active Member
    I think it's an emergency toothbrush. :)
  16. RodMoe
    Checking some sort of fluid level .. Or blowing bubbles maybe ...
    ronnie karlen, sparky and WScottCross like this.
  17. jimclark
    FWIW, I've got one in my box, too. Figured it was something or other, but I didn't know what, and just left it there until it became needed. Mine was actually in a plastic bag.
  18. Sekred
    Sekred Active Member
    This is a odometer override device. It is inserted in the ECU and allows ford to test drive the vehicle before it is delivered to the customer without the speedometer registering mileage. They do this to about 1 in 100 vehicles for pre-delivery quality assessment purposes. If you find this in your vehicle it simply that the driver forgot to remove after flogging your vehicle around a test track and the worst possible public roads and conditions the driver could find.
    Noah, LuvfiestaST, Firesail and 2 others like this.
  19. WScottCross
    Still laughing...
  20. ryst
    ryst Active Member
    Man so finding one of these is like losing the break-in lottery :(
    Can I insert this into my ECU now and stop it from racking up mileage?
  21. ryst
    ryst Active Member
    Also I can't tell if this is a joke or serious....
    ronnie karlen and LuvfiestaST like this.
