Will the Wilwood kit fit under 15" Wheels?
Discussion in 'Fiesta ST Chassis Upgrades' started by was-an-M, Oct 19, 2014.
  1. was-an-M
    was-an-M Member
    I have OZ Superleggera wheels for track use and after a few track days, the stock brakes are very inadequate.
    Does anyone know if the Wilwood kit will fit under those wheels?
  3. iLiptiKal
    iLiptiKal Active Member
    I can't say for your wheels, but the stock calipers have about 1cm of clearance from my winter steelies, so I'd assume with the bigger kit you will have issues
  4. razorlab
    I highly doubt the standard kit will.
    Here is a photo of mine under 17":
  5. timboslice
    timboslice Active Member
    No, it won't. Try talking to Joe at 2J Racing. I think he's done a modified kit for another member who runs 15s. I think it was RAAMAudio...
  6. raamaudio
    I ordered a kit from Joe at the GB price, with smaller rotors but then decided to get 11.75 GT rotors and made a deal on trading the unused lower cost rotors and 12.19 or whatever they are regular kit size and having custom caliper mounts made and then had to have more machine work done on them.....
    The only wheels I know that will fit and I can help get mounts made and a brake kit with the GT, etc rotors, Konig Dial in 15.9, +35, 13lbs roll formed and just $124 each which is a killer deal.
    Other than that, have not found another 15" wheel what will fit.
    I want a 15x8 for the street but the only ones are the Dail IN and not the right offset.
    If you want to run 11" rotors you can get a DP6 Wilwood setut but will have to have the mounts made, I can work out the info on those as well.
    I am retired, not making money on anything I do, just helping my fellow enthusiast as much as I can:)
