Winter Tires/ Wheel's
Discussion in 'Fiesta ST Wheel and Tire Upgrades' started by Mikeygti, Aug 16, 2013.
  1. LuvfiestaST
    LuvfiestaST Active Member
    3cm of snow forecasted for Wednesday. Guess I won't be changing over to stocks yet.. Does anybody have stocks on now in Canada?
  3. TapTapPull
    TapTapPull Active Member
    I think I'm booked in for April 10. I hope that's not too early!
  4. mrtn
    Rule of thumb I go by is change to summers when the temp is consistently over 10 degrees (Celsius).
    Probably won't do the change till mid April.
  5. marc89gti
    marc89gti Active Member
    I will probably wait to the end of April
  6. jimclark
    I'm in Kansas City, and am only changing from winter setup to summer (stock wheels and tires) tomorrow. No doubt could've gotten away with it sooner, but spring weather is an up-and-down affair around here, too. Heck, the Royals had a game snowed out last spring, so I could be doing it too early even now.
  7. jimclark
    High temps, average temps, or low temps?
  8. LuvfiestaST
    Are the stock tires all seasons?
  9. TapTapPull
    They're summer tires.
    P205/40-R17 Bridgestone RE050A
    summer-only tires
  10. LuvfiestaST
    Good to know.
  11. RodMoe
    Foot of snow on the ground going fast into the potholes that have opened up since we cracked 35 deg F today after a couple inches of snow last night .. LOL I'll leave the snows on till they are filled
    ronnie karlen and __V__ like this.
  12. LuvfiestaST
    Yaaaa tires changed over and TPMS reset...
  13. Firesail
    Spent this morning doing same. Glad to have summer tires on again.
  14. LuvfiestaST
    Yes makes a difference in the ride..
  15. Thibs
    Thibs New Member
    How do you reset the TPMS? Do you have to bring it to the dealer for that?
  16. LuvfiestaST
    Yes and here in Toronto it's $65 each time.. But I ordered a Ford Trigger gadget from Tire Rack and did it myself.
  17. LuvfiestaST
    Check out this
    Fiesta ST TPMS reset/relearn procedures
  18. F1ST
    F1ST Member
    When I put my snows on they had a new set of TPMS sensors and I used the tool from Tire Rack to train them to the car. This weekend i put the factory wheels and tires back on. I haven't redone the procedure yet and I haven't had the warning light has not show up so far. The stock stuff was only on for one day before the swap to snows, so I didn't bother keeping track of what corner they came off the vehicle. Can the system keep track of multiple sensors? I'm assuming you don't need to redo the procedure when rotating tires so corners don't matter?
  19. LuvfiestaST
    M
    mine were off for 6 mths and when I put the stock rims back on I had to reprogram them.. Took 2 minutes
  20. jimclark
    NO, you don't have to take it to a dealer. But you do need a tool to do it. Can get the tool from Tire Rack for about $45, I think.
    Procedure as follows:
    [Edited to remove the portion that does not apply to Fiesta STs.]
    If your vehicle has push-button ignition:
    1. Make sure all tires are inflated to the vehicle specifications.
    2. Make sure ignition button is OFF then press and release the brake pedal.
    3. Hold the ignition button down for 2 seconds, release it, and then tap the button once. The vehicle should be OFF. Hold the ignition button down for another two seconds, release it, and then tap the button once.
    4. Hold the ignition button down for two seconds again. The vehicle should be in RUN mode, engine off.
    5. Press and release the brake pedal.
    6. Tap the ignition button once so the vehicle is OFF.
    7. Hold the ignition button down for 2 seconds, release it, and then tap the button once. The vehicle should be OFF. Hold the ignition button down for another two seconds, release it, and then tap the button once.
    8. Hold the ignition button down for two seconds again. The vehicle should be in RUN mode, engine off.
    9. The horn should sound letting you know the vehicle has entered into TPMS relearn mode.
    10. Place the top of the FORDTRIGGER on the sidewall of the driver's side front tire in the location of the valve stem.
    11. Press the button of the FORDTRIGGER tool. The vehicle's horn will sound letting you know the sensor has been learned.
    12. Once the horn sounds, move on to the passenger side front tire and repeat the process. Each tire should only take 30 seconds or less.
    13. After the passenger side front tire has been learned, continue on to the passenger side rear tire and finishing with the driver's side rear tire.
    14. You may now turn the ignition to OFF. If the horn does not sound, the sensors were learned successfully. If the horn sound twice, then the process must be repeated because there was a malfunction.
  21. Thibs
    Thibs New Member
    Thanks for the info
